Camera Expert
All I know is that an equivalent Sony camera with a big chip and similar features with the XDCAM 422 codec won't be anywhere near the price of the AF100.
$5200 for an AF100 body with a couple of used Nikon primes and an adapter.
$5500 for an AF100 with the 14-140 lens.
So I may have been off by $59, but ... I think the point stands. You definitely don't need to go shelling out $12k to make a workable AF100 kit.
Sounds like about the same price as the fixed zoom Scarlet basic kit will be, give or take a few hundred.
And if I remember right (been awhile since I checked the specs), the fixed lens scarlet will have the smaller chip, effectively negating much of the shallow DOF that the AF100 is going after.
Not to mention the interchangeable lens option is one of the big draws of the AF100 for lots of folks.
A workable scarlet fixed lens kit will easily be over $7k. The $6000 fixed kit is really, really bare bones, and unlike the af100 basic accessories for scarlet (XLR module, additional batteries, etc) won't be cheap. "...count on it."
I shouldn't have derailed us by feeding into the never-ending RED cost debate; the new prices aren't even concrete yet.
Lets get back on topic.
Please explain this statement. Does 3k mean cinema where 2k means video???one's a video camera and the other is a digital cinema camera.
When will the 2/3" cinema (non-fixed lens) Scarlet be finally released? Are we certain by NAB?
Not true. With just the F3.5-f5.6 kit lens on the AF100, Scarlet fixed will pretty closely match for DOF at f2.4. There is not a radical difference in DOF between 2/3" and 4/3, about 1-1/4 to 1-1/2 f stops for the same FOV. 4/3 is about half way plus a little between 2/3" and S35 sensor widths for 16:9 HD. There is approx. 2-1/2 stops difference in DOF from 2/3" to S35. While it is not as easy to achieve shallow DOF at wider coverage angles for 2/3", it is worlds apart from your typical 1/3" camera in this respect. Just because most videographers don't typically shoot for shallow DOF with 2/3" cameras doesn't mean you can't get it at all.
Scarlet comes in two 2/3" models, fixed and interchangeable. Interchangeable (Cinema) model uses the same range of lens mounts that will be available for the S35 and Epic models, so full electronic control of Canon and Nikon lenses via their mounts will be included. For the price of a decent entry level B4 HD zoom lens or a current generation used S16mm manual zoom, about $8k, you will be able to buy both the fixed and interchangeable brains.
Well, asked to define the two in terms of differences, I'd say that a digital cinema camera is generally built to create images which strive to equal to or surpass film at even the most critical level. Right now, that usually involves a pretty major difference in acquisition format - AVCHD v. REDCODE RAW or ARRIRAW or straight up uncompressed RAW for example. It also involves imaging differences - digital cinema cameras pretty much all resolve at least a very clean 1080p image and many are displaying a lot of dynamic range (13-14 for M-X, 15 for Alexa, ~18 for M-X with HDRx).
I believe that Digital Cinema Cameras are also built assuming a nominal degree of production support, meaning that these cameras are built for use in a traditional narrative production environment - they have PL mounts, require more frequent magazine changes, store footage in relatively large file-sizes...they are heavier, larger, and generally more capable in terms of I/O and remote operation.
RED isn't the only one with a "Digital Cinema Camera". Arri has the D20, D21, and ALEXA. Many consider the F35 a digital cinema camera. There's the SI-2K. The Phantom cameras (though I'd say these are "Specialist Digital Cinema Cameras"). And the Ikonoskop and the Drama would also qualify, I believe.
There's nothing inherently good or bad about any camera being a video camera, a digital cinema camera, an ENG camera, or an industrial camera. They all have their niche, which is great. Specialization, in my opinion, allows people to do what they want to do better.
Ah yes, there are trade offs. Then if you want a decent intra-frame codec for the AF100 you will spend at least $2k for an external recorder too. For P2 AVC-Intra the price tag will be $4k.
Realistically they are both going to be $8k+ cameras for practical field packages. The AF-100 is a bit cheaper, with more typical video camera features and workflows but more limited in its imaging capabilites since it is still an 8-bit capture HD video camera. It really will depend on what is most important to you.
I like the 4/3 format a lot and the AF-100 is an excellent value no doubt. But having the creative flexibility to work with high resolution raw footage in ways that go beyond even my Nikon DSLR is by far the more attractive alternative to me.
I was not dissing AF100, which looks like a good product, but I am just voicing a word of caution to budget things right. This statement pretty sums it up.
Contrary to what Barry says all lenses are not equal.
But things which are objectively the best aren't always subjectively the best. And, frankly, a lot of people don't need really nice lenses.
