danny dale
Good to know. I have several of the older breech lock FDs and look to be getting a Speed booster soon. I have been using one of the original SLR Magic 12mm f1.6, but would like another wider FD to complete my set (24 f2.8, 35 f2.0 50 f1.4, 85 f1.8).
If you get a chance, please post some pics or clips with that 15mm when you get it - thanks.
Danny
Danny
Not really. I have a Zeiss Touit 12mm for my Fuji camera (1.5x crop), it also should be a fisheye, but it is simply an extreme wide on that camera. Since they sample only the central portion, you only get the light rays that follow that central portion, you could tape off a big hunk of the front lens and never know the difference on a crop sensor (and it might not be a bad idea to tape it off to prevent flair). This is overly simplified, but gives the proper idea.
That said there may still be some curvature, but I don't expect it to be worse than an old style 30mm on a 135 film camera, or worse than a 20mm on the same film camera when I have it mounted to the speed booster (if said speed booster ever ships) and the GH2. Video mode on the GH2 is said to be around a 1.86 crop so 15mm*1.86*.72=20mm equivalent to 135 film, not sure what the real viewing angle will be but you can look it up if interested. I'll almost certainly cut a plastic plug to attach to the front with a cutout large enough to clear with the speed booster to help prevent flair, once I figure out the opening size needed.
