vincent thomas
More footage and informations will be actually welcome, im keeping myself an eye on this camera even if Canon disapointed me lately
The ASICs on the Scarlet are running at slower MHz. It could be because RED wants to skim different market tranches, by selling an artificially crippled product, but it could also be because the ASICs can't actually run any faster.
Epic and Scarlet are the same weight. I'm not sure who has done it, but apparently a few individuals have done research and found that the inside of an Epic and Scarlet are Identical and your paying for firmware. Someone I spoke with said they knew someone that had gotten two Scarlets to run like Epics through creating new software in separate parts of the camera. Which would mean the insides are identical.
I won't say It's true, but it wouldn't shock me....
Perhaps if Canon had one or two different connections on the side of the Camera for the 1D-C than it would have been something more understandable, but just a firmware change in resolution recording, and a badge, hmmm, how many thousands is that worth? Of course the value of large sensor 4k is subjective in this market at this time, and while it may be feasible in a much cheaper model, there are still many early adopters that are willing to pay premiums. And yes, the coders and technicians need to eat too.
http://www.dpreview.com/products/compare/side-by-side?products=canon_eos1dc&products=canon_eos1dx
That you can hack/overclock Scarlet is not all that shocking, but it doesn't mean Epic/Scarlet differ only in firmware. I guarantee those hacked Scarlets have heat and/or stability problems.
This processor binning is very common, every chip maker does it: all transistors are imperfect, the worse ones will work only at increased voltage and/or reduced MHz, and the whole processor has to work at the voltage and MHz that allow its slowest transistors to work fine.
If RED's ASIC is big and complex, which I guess it must be, it would not be uncommon to have a yield of 30% or less, that is, 70% or more of the chips the foundry makes are unable to run at the desired specs. By defining a lower spec, you get a second tranch of chips that you can sell: they would lead to lockups and data corruption if you tried to make them run at the higher spec, but they'll work perfectly at reduced MHz and/or increased voltage. These are chips you would otherwise have thrown to the dustbin, so they're basically free.
Often, all of this is even planned in the design of the processor: nvidia and ATI design their chips in a modular fashion, so if a big lithography error appears in one module (one that will make the transistor unable to work, at any speed, or that would only work at unacceptably slow MHz), instead of throwing away the chip, the module can be shut down permanently and this "salvage part" can be sold.
Right now, nvidia sells several graphics cards that use the same GK104 processor. The top of the line is the GTX 680 (8 working modules, running at 1006 MHz), the second one is the GTX 670 (7 working modules, running at 915 MHz).
In the old days, before this modular design, the difference in MHz was bigger; it was not uncommon to have, say, a top part that ran at 450MHz, and a salvage part that ran at 325MHz. I guess something like this is happening on the Scarlet.
So far the hackers have been doing very well. Magic lantern is finally coming to the 7D, it took a while, but they just finally cracked it. And these are guy who aren't getting paid a salary. It might be time to start a kick starter to buy a couple 1DX for the hackers to work on.
If this camera delivers as much or greater real resolution as the C300 and gets 25p in 4K then I very much like it.
It's a different sensor and thus a different way of aquiring an image, so that's never going to be possible.
