Cannot get a particular clip from FS700 to go into FCPX, also can't convert it
Please forgive the posting of this problem on two forums, as it might be the camera and it might be the software. Maybe someone in this forum has had the same problem from this camera and will know how to deal with it. I will describe it somewhat differently in the FCPX forum.
I shot a series of instructional videos a while back. I used the FS700 on internal recording in the AVCHD format. For this particular clip I only need the audio, though I imported both the audio and video to keep things simple. I'm editing on an iMac using FCPX. There are over 50 clips in this particular AVCHD folder. For some reason, even though clip #42 imported just fine before, when I went back into that project for that clip it showed a broken link. I have two copies of that file on two different Thunderbolt drives, and when I use QuickTime player that particular clip plays perfectly from both of them, but it will not import from either of the saved versions. Every time I try to import it, the clip will not show up in the library.
I tried to convert it into another type of file using Brorsoft, both H264 and .mov. However, even though it is an 18+ minute clip, Brorsoft only shows about 8 minutes and starts near the middle of the clip. Starting at that point the conversion goes fine.
All the other clips that I have imported from this AVCHD file play just fine.
This clip is kind of critical, as it will be the voiceover narration for the on-screen video. Any suggestions?
If the clip opens in Quicktime, can you just export from Quicktime? You might need to have Quicktime Pro for this.
What about Compressor? Have you tried that?
Just before I logged on and saw your post, I discovered that after one of the updates QT will convert to other formats of video. I was able to output a .mov file and import that successfully.
It had been years since I had tried to use QT for anything except playing, so I wasn't aware of the new capabilities. No idea when they put them into the regular version.
