Candle light shoot advice
dtzfilms
Hi,
I'm shooting another music video for my friends and the theme is somewhat dark, based around the Hollywood Sign killer, and I'm opting to shoot at night. I don't have any lights, but my friends have some work lights. I'm going for a dark shadowy look during the "power outage" segment, and we're getting a bunch of candles to light up the cabin-decor duplex in the woods. I'm planning to bounce the work lights off the walls, or shine them in through the window to simulate moonlight if I need a few stops of light to get rid of noise. I don't really want to go over 800 iso even though I've seen videos shot as high as 1600iso. I don't have any of these noise removal plugins - might get one, but plan to shoot as if I don't. My voigtlander and Olympus will be seeing heavy time.
I might get them to rent an ARRI 3-head light kit, mainly because though it's tungsten balanced, it has daylight filters that I'm assuming I'll need to simulate moonlight.
This is my first attempt at a shoot like this, so any advice on pitfalls to avoid - much appreciated.
I intend to black balance a lot. I'll also be using my GH2 to supplement. My main concern is getting enough light, but being dark enough - say a 3:1 lighting ratio or even 4:1 without getting noise. Suggestions, advice welcome, cheers. We shoot tomorrow night, June 7th, 2012.
Tea light candles
http://www.ikea.com/us/en/catalog/products/50097995/
Colored candles
http://www.apartmenttherapy.com/colored-flame-l-98209
Colored candles
http://www.ehow.com/how_6535303_hang-candleholders-cracked-glass.html
http://0.tqn.com/d/fengshui/1/0/6/7/-/-/red-votive.jpg
http://ecx.images-amazon.com/images/I/41mLQLQcrYL._AA300_.jpg
You might want to consider renting a variable dimmer control to help simulate/augment the real candles. This can be done with a manual dimmer aka variac or a more expensive electronic automated one.
-Noah
-Noah
Did some searches, no luck so far. If it's not too much to ask, d'you mind linking me, please?
Cheers!
Re dimmers- worse case scenario, go to Home Depot, pre-built or make your own in an electrical box (cheaper).
Just be sure to get sufficient wattage rating for your lights.
I don't have a lot of experience shooting "Lit by candlelight", but imagine a warm fill on the faces would help, maybe with some "flicker" from a reflector with something moved in front of the reflector?
Hopefully you'll get more specific advice, but happy shooting!
The best "candle light" setup I have ever seen. 1 650 or 300 w light with a 4x4 ft gel frame infront of it, with CTO full orange inside, taped loosely, a fan was blowing on the gel in the frame creating the "flicker from the candle light all over the room. could work with the "work lights" you have. Make a "gel frame" from wired coat hangers and get some scrap gel from a rental house, a regular house fan and boom- you've got "candlelight" PS. you might want to have some diffusion as well, as those worklights tend to be harsh
wasn't my idea kids. I learn so much from other DP's just by working with them. If you are a new shooter GO ASSIST A VETERAN DP (its better than filmschool) - even better GO ASSIST 100 veteran dps, as they all know different tricks. I learn from gaffers as well.
