Can you fix my interview footage?
Tom Knight
Not sure if this is the right place to post this -
I am new with the camera and the lights. I think it came out great, except for that bright reflection on the right side of the frame!
Technical stuff - It's a DVX100B. Mini DV tape. I'm using Final Cut 6 to edit. Ultimate destination is YouTube, and then embedded in her web site.
I tried zooming in, but the image got fuzzy.
I'm wondering if I can do some kind of mask that can disguise the refection.
I'm also considering editing the whole thing in 4 X 3 instead of 16 X 9.
I could reshoot the whole thing, but I'd like to avoid that if possible!
Any suggestions from you pros would be invaluable.
- Tom
The camera is locked off so it's easy to fix. Pull a still frame from video and retouch in photoshop. Then composite back into video.
I just tried it, and it works OK. Luckily, it's an abstract painting, and not a picture of her grandmother or something. As it turns out, I know the artist, so he might not like the changes. But he will probably think it's funny.
A small trick would also be to add a slight vignette to the frame so that it draws attention away from the edge and focuses it on the subject.
Here's a quick fix. I think I can do it better, but I think it helps a lot. First you see the reflection, then you don't. Then it comes back at the end for comparison.
the fixed shot looks good, I'd second the blur/vignette around the corners if you're still worried about that little bit of light reflection that you can still see - otherwise solid job on fixing it. I'm assuming you won't make the same mistake next interview :)
Cheers,
Adam
Essentially some lens have light falloff around the edges. Often, a post process of this phenomenon, can help draw attention to the center area. All NLE have a plugin filter that can easy add this effect. It's very common in photography and film.
The fixed shot looks good. You could also consider slightly blurring/defocusing that side of the screen to even further reduce viewer attention to it.
