Can we change GH2 audio recording from 24/48Hz to 16/44Hz? (syncing problem)
Tim_
Is there a way
I can change GH2 audio recording mode from default 24/48Hz to 16 bit/44 Hz? ... I have syncing problem because my external recorder only records 16/44 :( please help
If you have a program like Pro Tools or Logic you can bounce out a copy of your audio with the correct sample rate/bit depth. Then it should sync.
