FilmBoy77 said:can the HVX emulate a shallow depth of field without using an M2 adaptor or Magic Bullet software? if so, then how?
i was looking at the dvd/book for the dvx and it says you can emulate this look in-camera.
4mat said:1 is incorrect you are thinking of 3
You do it the same way as the book/DVD tells you to do it for the DVX.FilmBoy77 said:can the HVX emulate a shallow depth of field without using an M2 adaptor or Magic Bullet software? if so, then how?
The reason is that zooming in all the way will get you a smaller aperture, which works against shallow DOF.ozduc said:Why do you think 1 is incorrect?
It is easier to achieve the shallow depth of field "look" with the camera zoomed all the way in on a long lens than it is with it zoomed all the way out or anywhere in between.
rapsucks said:My guess would be that if you had a large distance between your subject and the background, your best bet would be to back off and zoom in, but in this case, since the pill and bottle are so close together, maybe Barry's suggestion to go wide and close is better.
ozduc said:Why dont you try it and post the results. I tried it and as I said, it is such a wide angle of view when zoomed out, that everything in the background looks pretty much in focus and there is no way to get the pill to that size in the shot.
rapsucks said:...I would be interested to discover any mathematical formulae about DoF that might indicate when it would be better to open up and move in, and when it would be better to go telephoto and scoot back.
My guess would be...
