Can I power the HPX 170 plus an Aux from Anton Bauer brick?
RandyBurleson
I am looking at the possibility of using the new AJA KiPro MINI with the HPX 170 but it requires 12v not 7.2v that the 170 uses. Is there an adapter that would allow me to mount a brick battery or a DIONIC 90 battery to the 170 and have an auxillary XLR 4pin power out to power the KiPro MINI as well? I want this as compact as possible to use the 170 hand held too.
The answer to your question is, yes.
Anton Bauer makes an adaptor for the 170 that will allow the Dionic 90 to power it. The adaptor provides a power tap that, with the proper cable, will also power the Mini. I have and use that very same adaptor with the 170 although I do not yet own a Mini.
Check the Anton Bauer site for the correct model number as I do not have it in front of me at the moment.
