Can I mox formats on the same card?
Beeboop
I have A7s ii. Can I mix 60p, 24p, and 120p on the same card or do I have to switch out to a new card each time?
Do I have to do anything special to the formats in post on premier provider?
You can mix frame rates *and* codecs on the same card, no problem. In Premier you can put them all the same timeline, no problem either, but if you want slow motion you have to 'modify' the footage to play at a slower frame rate (e.g. 23.976). Hope that helps.
