GH4 camera lockups / crashes FW 1.1
Had my first freeze/lock-up today with FW 1.1, while shooting 1080/96. There was a mix of footage on the SD - 4K/23.976 and 1080/60 as well. Other 1080/96 was fine and once I pulled the battery and restarted, it recorded fine.
I have had this GH4 lockup on two out of two shoots. Shooting Cinema 4K/24P to a 64GB Sandisk Extreme card formatted in camera and a U3 Transcend formatted in camera. Both times were on long clips, over 5 minutes. What does "shoot without lens" have to do with this problem?
Bumpity bump.
Has anyone ever found a solution for this? I am running firmware v2.3 with a MetaBones SB and Canon glass (happens with the 24-70ii as well as the Tokina 11-16). This happened at LEAST twice per day last week while I was shooting constantly, and it was pretty frustrating/embarrassing to tell the talent to hold their positions while I reset the camera by taking the battery out. Then I have to line up the shot again, etc...
Shooting in 4K at 30p, if that matters.
Anyone heard of a fix?
SB
Allow me to chime in here. I don't have a GH4 but I recently purchased a Panasonic G7. The same thing was happening to me. Several times in a few days. Camera would lock up, would not stop recording, couldn't power the camera down, etc. Had to eject the battery. I was using a Lexar 128GB, 150MB/s, class10 (3) SDXC 11 card. No long clips, all 20 second or less. Shooting 4K, 30fps. It happened several times, so I sent the camera back after a week or so and got a replacement. Same thing happened with the new one.
I changed cards to a Transcend 64 GB SDXC 1 (3) Class 10 95 MB/s and have had no problems since. I also shot about 100 short clips with a SanDisk Extreme 45MB/s Class 10 SDHC just to experiment, and the camera had no problems with that one either. I am keeping my fingers crossed.
Don't know what any of this actually means, but I thought I would add my experiences so perhaps Panasonic can figure this out.
See, one of the reasons why I don't think it's the cards is because this mostly happens before I have even shot anything. Just turning on the camera, lining up the shot, and then walking away for a minute (but not long enough for the camera to go to sleep), and then returning only to find the camera frozen.
SB
Change the card anyway, cards are cheap and get a UHS-II card like Panasonic recommends. The other thing you can do is a factory reset and see if that helps.
SB
Are you using Panasonic batteries? Do you have the same issue without the adapter?
SB
I'm having a similar problem when shooting in stills mode using Metabones XL (0.64) and Canon L 50mm and 35mm.
I'll take a few photo's (90% of the time in Aperture Priority mode), leave the camera on for a minute whilst I'm doing something else, come back, and when I go to adjust the aperture, there is no change. All the settings are frozen. It won't even take a photo if I hit the shutter release. I need to turn the camera off, then on again.
I began to realise it always seemed to happen after I had used the touch screen to move the focus box.
One thing that helped, was going through and ensuring every auto-focus type setting was turned off. All of them. I feel like that was a problem. Maybe there was a hang-up in comms between the camera and the Metabones (or maybe between the Metabones and the lens).
Since I rechecked all those settings (after re-watching Dave Dugdale's GH4 guide), I don't believe I've had a problem.
I don't have any dedicated M4/3 lenses, so I'm only guessing.
Mine locked up a couple of times yesterday.
Was filming a wedding. All modes were working fine for the first 3 hours of the day. Start getting broll in church. Shots are locking up in UHD 24p. I have a sandisk 128gb extreme pro 95mbps card in at the time.
I think maybe it's the card, so I run to grab a 64gb extreme pro that's been freshly formatted. Same thing, locking up all shots! Finally try HD 24p @ 100mps, that locks up too! Ceremony starting. In a panic, I switch to avchd 24p and that works.
I had a safety cam, so I start attempting 4K again. MP4 (non lpcm) now works fine and works for the rest of the day on both cards.
What the hell? Maybe it was just a heat issue? I've shot hours and hours and hours of 4K on both of those cards without issue. It's the randomness that frightens me. I could've easily lost critical footage yesterday and very nearly did.
