Erik Naso
CAME-TV MINI 2 GIMBAL in Excellent condition. Comes with battery charger and 4 batteries. $500.00 With FREE CONUS shipping when payed with Paypal send cash option.
I've used the Mini 2 for several broadcast spots and it works great with smaller cameras like the Sony a7 and GH4 type bodies. The key is using shorter lenses. This makes balancing very easy. Sorry no pictures posted yet. I'll get them up this afternoon.
The CAME-MINI2 is the next generation CAME-MINI Gimbal. Compared to our original CAME-MINI V1, the new MINI2 is completely tool-less which allows the operator to change camera setups and re-balance the entire system very quickly. A quick release system has been added on the MINI2 for faster access to remove and install your camera onto the MINI2 Gimbal frame.
All of the wiring and electronics are completely enclosed into the frame offering a clean professional appearance and to protecting the wiring. Four 18650 rechargeable batteries are placed inside of the horizontal cross bar. The center handle can be removed with one knob, each side handle can also be removed, and the entire top cross bar can be separated from the lower frame allowing for compact transport.
A thumb controller joystick is installed next to the right handle that allows Pan and Tilt control of the camera or to switch through the different Profiles.
Profile 1: Follow Operator Pan and Tilt movement, Profile 2: Follow Operator Pan Movement (does not follow Tilt), Profile 3: Disable Follow for both Pan and Tilt.
July 3rd 2015:We have designed and added a new Stop Ring on the Roll Motor that will prevent the Roll motor from over rotating which may cause internal wires to tangle.
To check the maximum payload of this gimbal
Features:
1- Full 3 Axis Stabilization using the Latest 32bit Controllers with Dual IMU Sensors.
2- Compared to other types of 'Lightweight Dual Handed Gimbals', the CAME-MINI 2 is significantly lighter and smaller.
3- Completely Tool-less Frame with fast balancing with a built-in quick release camera plate.
The CAME-MINI2 3 Axis Gimbal Includes:
Features:
- CAME-MINI2 Gimbal
- Gimbal Balance Stands
- Custom Molded Carrying Case
- (4) 18650 Rechargeable Batteries
- Battery Charger
