reinvention.of.man
Items are in excellent condition
Cambo DSLR Cage
2x Cambo CS-154 Rod Clamp Quad Parallel (15mm) Retails for $178.95, 1x Cambo Rod Clamp Dual Parallel (15mm) Retails for $78.95, 1x Cambo CS-M5 Camera Mount Adapter Retails for $204.95
Also included in sale:
2x Ikan 15mm Rods (6"), 2x Ikan 15mm Rods (9"), 2x Ikan 15mm Rods (12")
The Cambo CS-154 Rod Clamp Quad Parallel (15mm) holds 15mm lightweight cinema standard rods 2.4" (60mm) apart and symmetric to the optical axis. When used with the CS-M1 or CS-M2 rod clamps, it allows the adjustment of the distance between the optical centre of the lens and the rods.
The Cambo Rod Clamp 15mm Dual Parallel is fabricated from high precision milled grade aluminum with a black anodized finish, with the front end featuring a mount for the CS-M1 or CS-M2 units. This mounting system allows you to adjust the distance between the optical center of the lens and the rods. The clamp enables you to attach two 2.36" (60mm) rods at a symmetrical position from the optical axis.
The Cambo CS-M5 Camera Mount Adapter helps you mount your HDSLR or DV camera on to a tripod or any other support. The CS-M5 comes with a mounting fitting, the Manfrotto 357 quick-release adapter.
http://www.ebay.com/itm/131504764476?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
Cambo DSLR Cage
