Mally Dangerous
Hey, have any of you guys used this? Is it new? Does it work?
Calibrated{Q} MXF Import?
About Calibrated{Q} MXF Import
Calibrated{Q} MXF Import is a QuickTime plug-in for NATIVE Importing and Editing of MXF Files within Final Cut Pro 6.0 and above. Calibrated{Q} MXF Import v1.2 supports the following MXF Files:
Panasonic P2 MXF Files (with separate video and audio tracks seen as 1 file):
- AVC-Intra
- DVCProHD
- DV50
- DV25
Sony XDCAM:
- XDCAM HD (35Mb and 25Mb)**
- XDCAM HD 422**
- IMX*
- DV25
Select OP1a:
- DVCProHD
- DV50
- DV25
- IMX*
Finally you can enjoy the freedom of native editing in Final Cut Pro without the need for Logging and Encoding, or creating QuickTime Reference Movies.
Calibrated Software’s unique solution successfully joins the separate video and audio P2 MXF files so that Final Cut Pro sees them all as ONE file - complete with TimeCode and Reel Name. PullDown can also be removed or added for select frame rates.
And you’re not just limited to Final Cut Pro, you can also natively import files in Compressor, Motion, Sound Track Pro, QuickTime Player and Shake.
(*IMX Audio is not supported)
(**XDCAM MXF files will take longer to open due to the long-GOP MPEG2 structure which may make it unsuitable for some long form projects in FCP.)
What’s New in this Version
- P2 AVC-Intra Support
- XDCAM MXF Support
- IMX MXF Support
- Flip Image
- New GUI for Options
