I have a whole bunch of cables, and I'd like a method to quickly pick up what I need and also to avoid confusion on set. For example, most of the time I can tell just by looking if a cable is 10' or 20' but not always, especially when you have cables of different brands, or the lengths are like 20' vs 25'. So I figured I can put a bit of yellow gaffer tape right under the xlr (or whatever) connector, sandwich it so that a little tag is left on which I can write the length of the cable (f.ex. 10') and any identifying info or whatever. The advantages are: (a)quickly can tell how long a cable is (2)there is no dispute about whose cable this is and hopefully cuts down on instances when it 'walks away', (c) if I always put the tape tag at one end (f.ex. always male, or always female), it is that much faster for me to grab the right end immediately.
Anyhow, I thought to do it with just bits of yellow (for high visibility) gaffer tape on which I can use a black marker - f.ex. tape like this:
Visual Departures Gaffer Tape 1" x 55 yards (Yellow)
But maybe you have a different idea or different label system, or no label system - what is your solution, if any?
