Trippy_filmer said:A good idea for quick removal, which is what i use and to get a tight rope is to add tie down straps at both ends. Tie the rope to each strap at each end, ratchet the straps around a tree, pole or whatever and then you have a tight solid rope and can easily and quickly cen be removed.
tomk358 said:I worked on a shoot a few months ago where they had a fischer cablecam system strung between the bleechers in a sports areana and a crane on the other end. About 1/4 mile run, and it could do 60mph.
They use 2 cables, one for it to run on, the other to pull the camera back and forth. Cables are 1/4" kevlar.
Hanging from the cart was a libra head, remote controlled pan/tilt head. This thing was programmed so as the rig swings in the wind, the head automatically moves the camera to compensate so the resulting image is quite stable. To control up/down they change tension on the cable that holds the rig.
They put a Varicam w/ Pro35 adaptor, 10:1 35mm zoom lens on the rig. To operate they had a guy with a laptop running things by wifi. The crane had an operator as well, which I'll get back to later. The set up some pre-programmed moves which they could run later, and also had a rig to control the position in real time. At the same time, there was another control station for the camera op, who could control focus, zoom, aperture. This was via wireles video sender, and the image quality was complete crap- but good enough to get the job done.
Now the fun part-
While testing the thing, at full speed, a pulley in the crane broke. The operator saw this, and hit the brakes- full on. Think of cracking a whip- only this one was 1/4 mile long, and made of kevlar...
When that shockwave hit the rig, it sheared off a 3/4" steel pin holding it on to the cable. The safety strap snaped as well, and I got a front row seat to view the distruction of $250K worth of camera- which fell and hit the ground in front of us. Landed on the lens- complete and utter distruction.
I shot a bunch of video of it, but haven't posted it yet.
wow this thread has seriously blown up, i almost had forgotton about it. i've contacted a few vendors about getting wireless lanc support for hvx/dvx and its doable but expensive. and i've got some drawings with a setup including a come-along and a rig with rc car motor driving it and servos controlling the camera turret. its going to cost me quite a bit to do this, my next freelance gig should take care of it. especially if i can find someone to get me parts at wholesale. but you guys just got me motivated again. heck yeah.
