Hi does anyone know if it is possibly to downsample 4K to 1080p in Premiere Pro ?
Thanks.
Another question is whether theres anything to be gained quality wise in 1080p downconversion between shooting the 4096x2160 24fps or the 3840x2160 23.98fps. 3840x2160 is the only 4k size option in NTSC 23.98 mode.
Of course it is. You can do just about anything you want with 4k footage in Premiere. Change the framerate, down scale, pan&scan, grab stills or anything else you want to do.
You also have to be careful interpolating 24p footage to 23.976 in Premiere. Doing so could cause your audio to change. You have to make sure your audio also changes by the same amount or else the sync could drift. If you do not need the audio then no big deal.
Honestly the main reason to shoot the full 4k mode isn't as much for broadcast as it for cinema distribution. If you plan on only ever broadcasting then there is very little reason to shooting the slightly wider than 16x9 format. Just shoot the UHD form of 4K and you have nothing to worry about. Save yourself the hassle of cropping and framerate conversion and just shoot UHD at 23.976.
About half a million more pixels.
Yes but do we know if theres any quality difference in how the gh4 is internally interpreting each flavor of 4K to get the different ratios. One might be encoded better than the other. Its binning or skipping in 1080p giving more moire.
So, doesn't choosing the 'Interpret Footage' option under Modify handle both video and audio?
No.
It all kind of depends on what aspect ratio you want. If you want to continue to have 16x9 then you will end up cropping off those extra pixels anyway. You will still only be down converting a 3840x2160 portion of the video. If you do not crop and want to try and fit the entire video you will end up with a tiny sliver of letter boxing in the 16x9 frame or a slightly stretched out video.
So if you plan on delivering 1920x1080 as a broadcast, Blu-ray, DVD or even web distribution there is no useful reason at all to shoot the 4096 wider mode.
