I am looking to buy this new lens from SIGMA
I wondering if anyone has this lens? The review has been nothing but positive from number of sites.
regards,
I'm thinking about this lens, but I'm not sure, as it is VERY SHARP... probably "too sharp" and may produce "fussy" Bokeh ... but I will TEST it after 4K update with 4K RAW to make my final decision ...
If you are going to buy Zeiss, get the ZF Nikon mount version. The EF version does NOT have a manual aperture ring while the Nikon version does. Very important IMO. I use my Zeiss ZFs with a Fotodiox Pro Nikon to EOS adapter than stack that on top of a Metabones EOS adapter and it works perfect. For primes , always try and get manual aperture lenses in Nikon mount and they will work on all cameras. For Zooms , Canon + Metabones is the at to go.
For Zeiss get it in ZF Nikon mount. Avoid the EF / canon version. The Zeiss EF and Nikon ZF mount are different because the ZF Nikon has an aperture ring while the EF version has NO aperture ring and is controlled electronically. That's a big difference. While the Metabones is great, it's still better to have a lens that does not need it to control the aperture because then you can use it on any future camera since it's manual. For example, if you rented an F5, the Zeiss ZF Nikon manual version would easily work, but the EF version would be a big pain because it needs electronic aperture control.
and yes, the Fotodiox Pro in the pic is the right adapter - Nikon to EF, and stack that on top of the Metabones. I have a set of Zeiss ZFs and they all have their own Fotodiox adapter to save time and speed up lens changes. It's more money obviously, but the convenience is worth it.
BTW, the 70-200 F2.8 II is a great lens. I have it. But you will need support. If you like to hand hold, I can post a pic of a little metal piece that I rigged up so it can support the lens easily without a base plate. I'll do it tomorrow.
Well, first I would say, if you're trying to mix & manage 4 mics on top of shooting and everything else, you should hire in a sound recordist. They'll show up with good gear, make sure everything sounds good all day, and take a sizable task off your mind so you can focus on shooting/directing/etc.
Having said that, I would wait for reviews on the H6 before ordering... The H4 is very popular but the sound quality is not considered to be that stellar. I've heard the Tascam recorders recommended several times as a better alternative, though I haven't used them personally. Something like the DR-60 would give you similar features.
For mics, it really depends on your budget. They're very much a "you get what you pay for" type of product. For a typical midrange setup, the Sennheiser G3 wireless packs are pretty much standard in their range. The Rode NTG-2 is a good boom option. If you had a little more to spend, you could upgrade the lavs included in the G3 kits (which are fine but nothing special) and upgrade the shotgun to the NTG-3.
But definitely consider hiring a pro to do it. Sound is one of those things that's easy enough to do an ok job at, but really requires attention and experience to do well. And that difference will be apparent straight through to the finished product- there's only so much you can do in post to fix a bad recording.
