One vote for dumb here. Live with the shallow depth of field you can accomplish with the stock lens or 1.6x or 2x telephoto attachments or rent the camera that will get you there.
Consider how users of the 35 attachment have to downgrade footage shot with the stock lens to better match footage shot with the attachment. You're losing resolution shooting the image off the internal screen on the adapter. Essentially you're shooting an image of an image instead of an image of an object. It's not a pixel for pixel transfer.
Sorry, but people have been hoodwinked. Lower image quality just to attain shallow depth of field? You're already starting with a 1/3" chip. Do what you can with a wider aperture, longer lens, composition, zone lighting et al.
The resulting shallow depth of field distracts the viewer from the resolution loss. I'll take high resolution over shallow dof any day.
The resolution on the ground glass is not 1080 or 720.
Forgive me for saying so, but you sound like you're saying that the adapter has a display inside - it doesn't. It's not a 'screen' in the electronic sense, it's a bit of glass. Adapters don't have pixels, they have optics. Yes you're shooting an image of an image, but it's not much different to using a multi-element lens in that sense.
I do know that there is a screen onto which is projected the light from the 35mm lens. It is not a sensor which resolves a 1080 or 720 image. It is naive to think that there is no loss of resolution when shooting off a screen. Ever hear of flying spot tele-cines?
There is plenty of talk about how there is about a %20 difference in quality between 1080 and 720. The eye can preceive a lot. I see the difference in quality between using a 35 adapter and a bare lens. Shallow depth of field might be important enough for some to lose picture quality, but not for me.
I understand that you have a lot invested in your stance.
But it's very simple, you are essentially making a copy of a copy. A digital copy (final image on the 200's chips) from an analog copy(projected image on the adapter's screen).
What users of the adapters are blown away by is the pleasing bokeh. I get it.
Resolution makes a difference if say you had the choice to shoot in 35mm film versus 16mm. You can't deny that. I'd choose 35, and I choose the crispest image from the stock lens on the HVX200.
your assertion that using a DOF adpater = loss of resolution appears to demonstrate a fundamental misunderstanding about optics and digital sensors.
If you wish to use your camera to create mood and meaning, it would be fair to say that a DOF adapter is an essential accessory and in that way, produces an image of far higher quality.
