burning hi def to standard DVDs
herbsart
How in the heck do you get your edited footage out of
fcp and on to a standard def. DVD. I shot a little two minute movie with my GH1 in the high def format, converted to 24p in compressor, ala the instructions on this forum, and exported it as a quicktime movie. when I tried to burn a DVD, DVDpro did not recognize the format. What do I do? I'm an amature filmmaker who wants to give his friends DVDs of my movies and maybe, someday post them online. Please help.
so you shot 1080p24, removed pulldown in compressor, and have your edited sequence in FCP. yes?
You now have to prepare your sequence to be burned in DVDSP.
Export your 24p sequence using "current settings".
Then open Compressor again. Import the sequence that you just exported. Look in the settings bin - drag the folder called "DVD best quality 90min " on to your sequence.
Then hit submit.
Your sequence is now compressed into a MPEG2 format which is friendly for DVDSP. You should end up w/ 2 files, an audio + video file.
hope this helps.
best
Z
Thanks for your quick answer. Yes, I've done all the above, but when I try to play from the DVD I just burned, on my iMAC, It doesn't recognize the 2 files.??
thanks
Herb
Herb are you just burning the files onto the DVD or are you importing the assets into DVD Studio Pro?
Noel, I've tried both. I burned half a dozen DVD's ( coasters anyone?). I either get, A: a quicktime file that freezes and skips on playback (too large?), or B: a disk with two files the computer can't read but will play on my TV's DVD player. Is there some format in compressor or DVD studio pro that will allow me to play the DVD on both the way rented movies do?
thanks
Herb
Then hit submit.
Not to beat a horse to absolute death BUT.....
You should start with what I've said here...ok?
THEN-
You must open DVD STUDIO PRO,
Import your assets into DVD STUDIO PRO (Video file + Audio file) After it has come out of COMPRESSOR (as I've stated above) they should be an M2V file(video) and an AIC file(audio), (I believe...I dont have in front of me).
If you just want a "play only" dvd w/ no menu
In your "graphical Pane" delete the default 'menu' track.
Then- highlight track 1, right click(control click) in the drop down menu, click on "first play". When you assign your assets to this track it is telling the dvd to 'play' this track first, as opposed to looking for a menu, etc.
Then in the 'assets' bin highlight both your video/audio and simply drag to 'track 1' in the graphical pane.
Then you want to make sure to tell the DVD to return to the beginning of disc at end of program so you need to highlight the 'track 1' in graphical pane.....then look over at your inspector...where it says "end jump" - "not set", you want to click on the drop down menu and select 'track 1'. This tells it to go back to the beginning of track 1 when it reaches the end of track 1.
THEN-- go to FILE>ADVANCED BURN>BUILD & FORMAT.
Viola- you should now have a playable dvd:bath:
This is all very basic stuff, it might help to watch the video tutorials that came with FCS, or look up some video tutorials online for basic FCP/ COMPRESSOR/dvd workflows
cheers
Thanks Zack, I'm not a pro editor, just an amateur filmmaker, so I guess I didn't realize that when I jumped from HDV to the GH1 with true HD that I would have to go through all these steps to get HD on an SD disk. Thanks for explaining it so clearly to a newby.
Herb
no worries at all herbsart:cheesy:
but to be clear...there is nothing 'PRO' about this explained DVD process. there is really no difference whatsoever in burning DVD's for SD footage or HD footage. I'm not sure what you did differently for HDV? But nothing changes for burning an SD DVD.
concerning the GH-1 prodduction/post workflow (pre-dvd burn)- here is where I understand where one could get a little caught up, i.e removing pulldown, overcranking(slo-mo), shutter speeds, 720p60 vs. 1080p24(60i), etc, etc.
However, I'm still confused as to what is different about going to DVD?? Once you've overcome all of the acquisition/edit hurdles of the GH-1... going to DVD is virtually the same as if I shot and edited on the DVX100?? minus maybe aspect ratio or something....
I dunno- glad I could help.:2vrolijk_08:...did it work for you??
