hganzler@earthlink.n
Hello; I am trying to burn a dvd shot in 24P. Please help me learn the correct settings for capturing, compressing, and burning.
1. I am using FCP. I caputure the footage shot in 24P to FCP in 29.97.
2. Next, I have to export the captured clip in a QT movie. Do I export in 24 or 29.97? When I've exported in 24, I get terrible studdering and skipping in the final DVD.
3. I next compress the exported QT movie in Bitvice. Do I compress in Bitvice using the 24 frames setting or the DV NTSC 29.97 setting. When I've used the 24 frames setting, I also get studdering and skipping on the final DVD. This has happened when I've exported the QT movie using both 24 and 29.97.
4. In Bitvice, I have not checked the "interlaced" box nor the "remove interlace" box since the 24P shots were not interlaced. Is that correct?
I can burn a good DVD with the clips shot in 24P when I export the QT movie at 29.97, and compress in Bitvice at 29.97. But I had heard it was possible to burn a 24 fps DVD and that this would have better resolution since there were fewer frames to compress with 24 than when using 29.97. Am I misunderstanding something? Thanks for your help. Henry mindfulproductions.com
