Forget the paint menu.
I use MLUT in F35 and record burned in stream via Monitor Out. This looks best.
Better than hyper gammas. F35 in paint never works.
In Cine EI mode, just assign the MLUT to any of the custom buttons. It’ll even push the LUT to 1000EI when changed.
You could also change the MLUT to be HG7 or HG8 in CINE mode when s-log is the profile.
I’ve been playing around with the Special HG8ISO800 gamma, really punchy image and when pushed to +6db, it gives a nice “film grain”
Gonna play around with MLUT again !
Here are my most recent settings...
Went a little extreme to push each setting, looks nice baked in with the MLUT, which allows for 109 IRE with slog.
Expose 18% gray around 33-38 IRE and you’re good to go !
CUSTOM MODE
EXTEND
F900R
MLUT (operation menu)
HG8009G40
PAINT SETTINGS:
S-LOG GAMMA
BLACK GAMMA
M -99
RANGE: LOW ; ON
SATURATION:
-20: ON
LOW KEY SAT: 99
RANGE: HIGH ; ON
DETAIL: ON
LEVEL: -60
CRISP: 99
LVL DEP: 99 : ON
But why not slog? Or this is for jobs that don't grade only?
I’m talking about standard MLUT built into every F35. Its assignable to show up on monitor out
. It’s not true Hyper Gamma goes up to 109 - still caps at 104 same as SLog, check it in histogram.
