Yes I have often thought this to be a sealed unit, having spent some years in clean rooms. Surely someone from Panasonic can demystify this for us? I would love to know. (doesn't help the OP of course-) If his camera is under warranty and has clearly not been exposed to limestone quarries or similar, Panasonic should fix it, or at least provide a cleanup service at a sensible price- the PR would massively outweigh any small cost to them I would have thought.I feel your frustration. I wouldn't be surprised if they've just been cleaning the outer housing glass. cleaning inside the sealed chamber requires a static free clean room, not something that's usually in a small operation like you described. Get it to panasonic directly, not a shack on the blvd.
i may have missed something:drogar-shock(dbg):
Cheers!
Rod
Unfortunately, this seems to be a trend with certain companies. Never had a prob with Panny but my friend recently had a problem with Canon. You really shouldn't have to harangue these people to get service, especially if you're spending thousands on a piece of professional equipment. I feel like it happens more if you're under warranty because they're not getting the $ for their time/parts... You really should insist on sending your camera to another authorized center because this one is obviously not doing the job. In the meantime you may be able to use a screw on ND filter in place of the dirty ND?
Once the dust settles on this we can CERTAINLY make some noise seeing as I'm not the only case.
Oh, and they ARE telling me that the only way to change out the ND wheel is to change out the ENTIRE CMOS ASSEMBLY. Thank god Panasonic doesn't make cars.
"That oil change is gonna require a new engine sir" WTF?!?
What a terrible, terrible design flaw.
it's probably less complicated than that
it's a sealed unit, having a facility that is equipped to open it and repair it probably would exceed the cost of just swapping out the whole unit with another factory sealed unit.
what you could argue is that they might have been able to find a way to have the sensor exist outside that sealed unit, but that is highly debatable
Effective strategies need to set a reasonable balance across all their component parts.
If customers get the notion that equipment cannot be repaired, they will cut their losses and start shopping around.
"Panasonic lost $9Billion dollars in 2012, $7Billion in 2013..."
Yes and they should ask themselves why. With such support on their products, no doubt people turn to other brand.
the loss is not the reason for the lousy service, the lousy service is the reason for the loss...
