Jarrett P. Morgan
So I love lekos. One of my favorite lights really. bouncing into cards, ceilings, punching through windows, etc.
That being said, when shooting daylight scenes, a leko with full blue on it doesn't have much punch and renting a Joker-bug and adaptor is 300+ a day. Most productions that I shoot for don't approve it as it is considered a "luxury" item unfortunately....
So, I have decided to build my own. I have been doing considerable research (sources listed at bottom) on metal halides, ballasts and bulbs and think I can do a 400W for around $600. Here is how I plan on doing it:
Bulb:
The bulb is just about the most important thing in the fixture; it dictates the color temperature, color rendering index, and intensity.
I chose this bulb:
http://www.bestbulbsdirect.com/Philips_MSR_400_Replacement_Jenbo_NSK400
(Manual/Specs for Bulb: http://www.jenbo.com/upload_file/product/file/000013-20081002150824.pdf )
although a bit expensive at 100 bucks a pop, the specs all say that it will be beautiful light, and the GX9.5 base means it is small enough that it should fit into the leko.
Leko bulbs are special in how the bases are designed, with a built in heat sink and a G9.5 base. I could not find a G9.5 metal halide bulb with proper specs, nor a leko fixture with a GX9.5. so I will need to change out the base in favor of a base for a GX9.5 bulb (which seems to be somewhat difficult to fine):
http://www.nationallampsandcomponen...&-GX5.3-&-GX9.5/Gx9.5-Lamp-Holder/21/262/1860
Fixture:
Ebay is full of old lekos and off-brand ellipsoidal lights. I have been looking at a couple, though are really interested in these:
http://www.ebay.com/itm/Altman-Shak...age_Lighting_Single_Units&hash=item2a250dd312
http://www.ebay.com/itm/Source-Four...age_Lighting_Single_Units&hash=item20ccfb6088
http://www.ebay.com/itm/Altman-360Q...age_Lighting_Single_Units&hash=item1e69271683
The fixture isn't super important, as long as the degree is correct (I am looking for somewhere between 20 and 30 degrees)
Ballast:
The ballast is also very important, and I think I have found a nice one in this:
http://www.ebay.com/itm/Hydrofarm-P...338?pt=LH_DefaultDomain_0&hash=item2ec23b626a
(Manual for Ballast: http://www.hydrofarm.com/downloads/fc/PHANTOMInstructionsB_20298.pdf )
Although I have found nicer ballasts elsewhere, they would require building an enclosure around it. The ballast listed has a nice handle, passive cooling, and a built-in breakers to protect it and the bulb.
I am planning on replacing the connector on it with a speakon connector (http://en.wikipedia.org/wiki/Speakon_connector) so I have a nice locking connector. Then build a header cable with speakon connectors and replace the leads on the leko with the same. It is a professional speaker connector that should be able to handle the wattage just fine.
Other Items needed:
All I can think of that I will need is a TVMP connector (to convert the leko to a stand vs the pipe-clamp) and perhaps an inline switch for the ballast (or I may open it up and install a switch on the housing)
Thanks for letting me lay out all of my plans. Please, if you have ideas or opinions on this, speak up. I would love to hear them!
Jarrett
Sources:
http://konvas.org/how-to/diy-hmi-1.html
http://www.coollights.biz/wordpress/archives/36
http://www.coollights.biz/wordpress/archives/33
http://www.coollights.biz/wordpress/archives/31#more-31
Bulb:
I chose this bulb:
Fixture:
Ballast:
Other Items needed:
Jarrett
Sources:
