Hi everybody. This is my first thread here, but I've been observing for a while. I think I have most everything I need here. If there's something I missed, feel free to ask.
I've done quite a bit of research by now on how to build a jib. However, I do need some help with a few things.
1. Does anybody have ideas for a good way to make the jib sectional? I'm thinking 3' sections, but I'm not sure how to make it fit together well enough for a shot that's not very shaky.
2. Can anybody tell me what plugs I need for remote Zoom/S-S and Focus/Iris on a Panasonic DVX100B, and how to wire said plugs?
3. Do you think I should wire my own LCD monitor, or buy one? I'd like to save $50 and wire it myself, but I don't have a lot of experience with wiring. I am proficient at soldering and the monitor I'm thinking of wiring comes with a wiring diagram.
4. Remote Pan/Tilt. I have access to some good quality 360:1 geared motors for about 20 bucks a pop, so that's not really the problem here. But I'd like to know if anybody has advice on how to make the head smooth and not shaky, how to wire the motors (as in where should the wires come out, etc.), and if you have any suggestions for a good-quality, cheap joystick to control it.
I will be using four 1" square aluminum rods from Home Depot for the arm, two on top and two on the bottom. I may surround that with an aluminum casing for looks and for other reasons, namely having the wires not interfere with the action of the jib arm.
I intend to build my own tripod, but if someone can interest me in a tripod that can hold 50 lbs. for under $100 that would be very nice. However, as I have not found one of those yet, I'm thinking it's DIY on the tripod, too.
I do have access to welding supplies, but I'm not the one who's doing it and I'm not sure of the proficiency of the person who is, and whether I can trust them to weld it the way I want them to.
I will have weights on the short end, of course, to balance it out. I just hope my weight set will work for this purpose!
Camera will be a DVX100B. Not mine, either, so I need to make sure this thing can hold it securely.
I do not have plans on the computer, but I have drawn some up on paper.
