stefanocps
what are you suggestion for a budget slider that i will use with my panasonic gh3(with some option, like monitor and may be matte box, all in the same cage))
I would have recommended at least 1 inch black iron pipe, and 2 inch would be better. The problem with this pipe is that it isn't perfectly smooth so you will probably see little variations as you slide. It's close and you may be able to make a poor man's vertical lathe to shape them smooth. The big thing is the black iron gas pipes are fairly thick which gives good strength.
those with wheel are all short in lenght is it? how do you use the wheel?i mean i supopose you use in the pavement, and the camera is it very low positioned. is that?
someone told me that a follow focus will never work in sucha cheap slider as the pressure will cause too much unbalance
what do you think?
