Eimulis
http://www.ebay.ie/itm/-/201936503911?
Selling my DIY Brushless Gimbal. I was using it with my Kienmini camera, weighing ~2 KG. I think it should work with cameras up to 2,5 kg.
It is made from carbon fiber and weights ~2 kg.
It powers from 4s battery and uses Alexmos 32bit controller with 2x IMU sensors. Most of the wires are hidden in the tubes. It has joystick, on off switch and button to change Gimbal modes.
It also has power distribution board, powered from separate 3s battery with 5v, 8v and 12v outputs to power camera and other accessories.
There's a monitor mount and hot shoe mount to mount accessories.
The distance from camera mount to the horizontal tube is 15cm, so the camera+lens can be up to ~30 cm in length.
It comes with two stands for balance, 2x 4s 5000mah batteries, battery charger, hex screw set, and transport case.
I highly recommend to buy it if you have DIY gimbal experience, or at least some DIY electronics skills and ready to learn how to balance configure it.
