Broken Tripod!!
DarlingDimple
Carbonite Member
I have a bogen manfrotto tripod..and my head is totally screwed up...it wobbles...it not major problems but it needs a tune up...where can i go?
What head do you have? I had that problem with the the 501. there were three screws on the bottom that just needed to be tightened.
Sounds like you just need to tighten the screws going upwards into the head from the shaft. Loosen the screws and then rotate the head clockwise to tighten it, then screw in the screws to prevent the head from moving.
