So my af100 hit the deck with ef24-105+Redrock live lens adapter on the camera.
Since the camera booted up right away, my thoughts turned to the lens, which was also fine, though I am getting it checked.
what wasn't fine was the ef mount in the Redrock adapter, it was buckled.
it took a bit of work to remove the lens, and the adapter needs to be repaired, hopefully just the ef connection plate.
But then removing the adapter from the camera revealed the next problem: the flange on the camera was also bent. Since we needed the camera to shoot, I took the flange off of the body and tried to straighten it. I wasn't expecting much and that's what I got, no dice.
today I took it in for repair to digitron here in Los Angeles.
they said that the flange, that I had removed with 4 screws, was not a replaceable part.
Therefore they would have to replace they while head unit to the tune of $2000+
So after all that, anyone have any ideas where I can find this simple metal piece?
