DavidChia
U.S$ 105 Shipped anywhere to the world with registered mail. Payment via Paypal only. Item is in Gremany, so E.U buyers save on tax.
I can say that after owning the Original Brevis mount and Geardear lens mount and Cavision lens mount. I came up with this solution. The rubber paddings absolbs the vibration of the Brevis or the Letus and also grips the Lens .
I made a 2 extra lens support . I'm currently using two and will be also using it for my Letus extreme that is coming.
Brevis to rail mount ( modified) from the Cinevate Universal Blocks (15mm standard) I use it as a long lens support and also as my Brevis support. It is rubber padded so it does not scratch the Brevis , Letus or lenses and it is also height adjustable (45mm to 110mm measured from the top of the block to the centre of the lens). It is more then enough for matte box or follow focus unit.
It is also galvanized to make it black not spray painted. The diameter of the clamp is between 75mm - 80mm but because of the rubber padding surrounding it . It clamps between 73mm - 78mm. Thus making it perfect to clamp even the Letus Economy (76mm) down on to rails .
It is fully lockable with an internal locking screw and nut so that it doesn't turn or tilt. I will also throw in a HEX key for the locking down of the screw.
And when you take the top piece up , it will work as a long lens support and cushion your lens and protect it from scratches.
The original Brevis clamp cost Canadian $135 + shipping + tax )
Email me at davidchiaemail@yahoo.com.
I've sold many many things worth up to I can't remember here without any problems.
The clamp unit below is the one for sale ( every unit consist of a clamp support and a 15mm universal mount block from Cinevate):
