Up for sale is a barely used Brevis 35mm MP.2 adaptor with a CineFuse 1 ground glass. The unit also comes with the Cinevate flip module which optically flips the image back to the proper image direction with almost zero light loss.
Rod support system: I'm also including the rod support system, which is necessary to take the weight off of your camera threads and so that you can add a matte box.
Nikkor lens mount: I'm including my nikkor lens mount which allows nikon film camera lenses to be mounted to the unit.The only issues with it is that it's missing the little screw that locks the lens into place. It still locks but I just don't twist the lens in all the way because without the screw, you have to use a pin to unlock it. I'm sure it's very easily replaceable.
Also, I am including the charger, but the last wire segment of the charger that plugs into the Brevis is missing. You should be able to find a replacement plug in a good electronics store and solder it back on and if not you could buy a new universal charger.
This cost me over $1500 new!
$750 obo
$750 obo
