Brand New CX350, Audio Channel 2 doesn't work. Advice Please
nedcam
Had this unit about 3 weeks and due to travel, the holidays and being sick today is the first day I really gave it a thorough testing, hoping I could use it for a talking head tomorrow and Thursday.
But there is nothing I can do to get Channel 2 using an external mic to lay down audio. The internal mic's Ch 2 works.
• I used 2 different mics I know to be good, with and without +48v
• Used every conceivable input setting and have read the manual and Barry's book. Tried 0 & +4db. The output is stereo.
• The VU meter shows a good signal but there's no audio playback of Channel 2 (which by the way should have been labelled Ch 1 because that's the jack we will use because it's closer and the editors always go to Ch 1 first as the usually better track. Go figure)
• Played back using VLC Player (QT won't work for some reason with the CX's 1080 mov) with a Mac Book Pro and 27" iMac.
• I have not inputted it into an edit program, I need to hear both channels on location from a laptop for client approvals.
• I was a soundman in a previous life where we used Nagras (Google it), so I know a bit about audio, but perhaps I'm missing something here? I've tried every combo.
Thanks,
Ned
Ned, please contact Panasonic Sales Support and our engineers can help you figue out what's happening.
877-803-8492
Mon-Fri 9am-8pm Eastern
A few questions:
  1. What are the settings of the CH1 and CH2 Select switches for the audio channels on the side of the camera?
  2. Which XLR input is the microphone connected to, the XLR connector on the top handle to the right of the screen (Input 1), or the one at the bottom rear of the camera (Input 2)?
  3. If you monitor the audio signal with headphones while recording, do you hear the audio from the microphone input?
  4. If you switch to using channel 1 rather than channel 2, does the audio get recorded correctly then?
  5. What kind of microphones are you using? Do they require 48V phantom power?
Note, that I believe if the audio level options in the menu are 0dB and 4dB, this indicates that the audio input is set to Line level rather than Mic level. If the audio input is set to Mic level, then I believe the input level options in the menu should be −40dB, −50dB, and −60dB.
One other thing that might be useful, if you press the Disp/Mode Check button for a second, it will display camera status information on the screen so you can see what the camera settings are currently set to. If you cycle through the different status screens, one of these pages shows the current Audio settings of the camera, which might be helpful in troubleshooting.
Thanks Andrew,
I am about to call Panasonic's Sales Support as Mitch Gross recommends, I have it all set up on my desk so I can go through it with a tech.
As of now, no combination of input selections, various microphones tried, phantom vs battery power, etc. will allow a signal to be laid down, although Ch 2's VU meter indicates it is reading an input signal.
ALTHOUGH CH2 HAS A VU METER MOVING I ALSO DO NOT HEAR IT IN MY HEADPHONES, ONLY CH 1.
Once we figure this out I will post the solution so anyone else with the problem will know how to correct it. I hope not to have to send the unit in because I have a shoot on the 20th I can make some money with it.
Ned
P.S. Just called them, they will call back within 4 hours.
The Latest:
• I just got off the phone with the highest level of Panasonic's tech support and he said it is a bad switch for the audio controls.
• I am seeing if I can replace it for a new one with B&H. I hate having a bad new unit and who knows how long it would take for it to get repaired.
Ned
UPDATE: Perhaps because I got the two year extended warranty: B&H will send me a new replacement when I send this one back. I am a little skittish now. Besides this audio problem which may be mechanical, the camera bricked up on me once when I was rolling, I had to detach the battery to get it started again. To get it fixed at Panasonic would be a two week process so my advice is to always get the extended warranty at B&H.
Otherwise I am liking the camera, i tested it side by side with my C100 during talking heads yesterday, mainly to see the difference in DoF, I'd say throwing the background out of focus is very doable with enough distance, not as soft a background as the C100 but looked nice. I have learned that I will need the High Sensitivity feature on for all interior interviews though, otherwise I'd need to be wide open with extra db.
I had the camera brick up on me a couple of times and the only way to stop was to eject the battery. I discovered that this only happened when using a card that couldn't cope with the data rate. Since using different cards I have had no problems. Hope that helps.
Very pleased with the camera even though I also own an FS7 and FS5 II
The one time I had a CX350 lock up on me, it was also card speed related. The camera had actually recorded to most of the card, but apparently the write speed toward the end of the card (as the card filled up) couldn't keep up with the data rate. Interestingly, I had the camera connected to an external monitor over HDMI at the time, and the camera was still sending out a video feed, but the frame rate of the HDMI output had dropped to what seemed like a few frames per second.
When I tried to interact with the camera, none of the buttons did anything and powering the camera off and back on again was the only thing that restored functionality.
I stopped using that particular SD card, and haven't had a problem since, so I'm pretty confident that it was a card issue. It would be nice if the camera handled this situation a little more gracefully though.
I think we should start a thread asking about if users have had it brick up on them BUT don't use the verb brick, many guys won't know what that means.
What it means to me is: Can I trust this camera on a live shoot such as a speech or press conference when I can't be on AC power? That's how you lose a client. It will cause me anxiety, like when you have a radio mic you can't trust but had to use.
As to card speed, I bought the best, the one recommended in Barry's book, the SanDisk 128GB Extreme PRO UHS-II SDXC Memory Card from B&H for $200. I only buy cards from B&H and Best Buy due to the controversy of the Chinese making perfect looking counterfeits (Google it) so those are the only two sources I trust. Where did you buy yours? Not Amazon I hope.
I just went through the hassle of boxing up my new camera and sending it back to B&H for a new one. Besides my audio issue I never got the HDMI out to work, so maybe the new camera will be a more recent serial or hopefully not made on a Monday. I really want this camera to be good, I don't see an alternative besides spending an additional $3K for a Sony FS5 and using their kit servo zoom. I'm done with swapping still lenses in a hurry. Did that yesterday with fast moving b-roll, ugh.
Best,
Ned
Hi GGeoff,
May I please communicate with you off the forum? My email is ned (AT) nedmiller.com
Many thanks,
Ned
Best,
Ned
When I ordered my CX350 from B&H also ordered the Panasonic brand 128GB V90 memory cards. Expensive cards, yes. Never have experienced any recording or "brick" issues. Never could understand why buy cheap memory cards. In my opinion the risk is not worth it. Prefer peace of mind to saving a few bucks.
One does not need to spend big for this camera's memory cards if you stay with long GOP recording. B&H has the Sandisk Extreme 128GB 170MBps cards for $45. A trusted name and plenty of speed for all of the recording modes.
That card says V30 so you're right, it would be a good choice for long-GoP recording.
Again, "170mbps" is meaningless in the context of camcorder usage. The ONLY number that matters is the V speed rating. If it says V60 or V90, it's good. If it says V30, it can be used for long-GoP but not ALL-I. If it doesn't say V30, V60 or V90 on it, don't buy it, regardless of how many megabytes per sec it claims.
A genuine SanDisk bought from an authorized SanDisk seller is a good card, but do pay attention to the exact card you're getting as to it's V rating, SanDisk has a whole lot of "extreme" and "ultra" and "pro" names and it can be confusing. Especially with the obscene level of counterfeiting going on out there.
