GH4 Bmcc rig for gh4
No experience with this kind of setup but just from observation it looks like it should work nicely. You should have access to all the ports on the left of the camera and your screen should be able to swivel freely. The one issue I can see is you'll need to remove the camera from the cage to replace the battery since there is no cutout for it.
Thank you for answer. I ordered this and it is on the way to me. Removing camera to change battery is not a big deal since there is a quick release plate. The only problem is/was that camera sits very low so it is almost no way to install mattebox, even if it is adjusted to the lowest position. Thats what they told me. But for $20 they made set od shims for me sa cage can be lifted higher. I was thinking about adding baseplaye inside the cage right under the camera because they said there is about one infh qbove the camera. But we will see.
I received this cage and I have to say it is very good quality, rigid, handles are made very very nice. The only think i don't like is that it is very bulku with gh4. I didn't think it is going to be that big. The other think is that access to any wheel on the camera (aperture and shutter) is very limited and kind of hard. I knew this button in the handle doesn't work with gh4, but it would be very helpful. So because of this i will probably return it. I love it but with gh4 it is unfortunatelly not very easy to use. Specially controling exposure. It is going to be listed on the forum so if anybody would be interested let me know. Instead of paying for return shipping i can try to sell it first. I have 14 return policy anyway.
