naughtygeorge
How do you focus on a subject and blur the backround and vice versa?
Envision said:You can increase your DOF (depth of field) by getting a 2x telephoto converter for your DVX
KHendrix2 said:"You can increase your DOF (depth of field) by getting a 2x telephoto converter for your DVX"
This should read "You can DECREASE your DOF" or "You can increase your SHALLOW DOF" "by getting a 2x telephoto converter for your DVX".
No wonder people get confused.
As far as the "MANY filters available for this", the first two look like crap and the third one is a split-field diopter that is designed to increase depth of field, not decrease it.
KHendrix2 said:As far as the "MANY filters available for this", <snip> the third one is a split-field diopter that is designed to increase depth of field, not decrease it.
Lensmith said:All the tricks in the world won't work if your subject is only a few feet or inches in front of the background.
Envision said:Unless of course you're using one of those soft screens for the background, or a 35mm adapter ... with the 35 Adapter and the right lens, you can have a RAZOR sharp shallow DOF ... which if you're not careful can work against you as well, as pulling a good focus on your subject has the potential to be even more challenging as there's less room for fogiveness in the focus.
