Clip link at end.
Let me set this up a bit first.
GH1 unhackable with 14-140 kit lens.
The stage has two banks of lights aimed at it, both left and right. These are both clear and and with gels attached. The lead singer, very fair skinned and very light blond hair. The white guitar has white MOP plate behind the strings. Flashing lights on the rear of stage are mainly covered in a reddish/orange gels, with some blues and some yellows. WB is pretty close to dead on. Some of the colors could use some help.
When the lead singer or the guitarist steps into the direct light aimed at them, the white guitar blows out as does much of the singer's skin and hair.
I started in IA as this was a test run to see what the cam might do. I went around the dial hoping to find something that altered the situation but nothing did. I manually kicked ISO down to 100 at one point and lens was at 5.6. When I hit shutter priority it was out at 250.
I have shot footage of this band many times with my consumer SD pannys and later my DVXs. The only times we were able to keep this from happening was with the DVXs and cranking gain back almost as far as we could.
Is this an ND filter situation or cam settings ??? If an ND filter situation, what range 2, 4 or 8 ?? If cam settings, where do I start ??? If both, ok, can you aim me where to begin ???
Thanks in advance.
http://www.vimeo.com/19358180
Thanks in advance.
