Here is the first shot from the Ursa 12K, using the same 85mm lens at the same aperture T4.5, same WB 5600K, later in the day, couldn't help that, so the light is definitely not the same. Ursa was shot in 12K 60 FPS at Q5 compression, rendered in 8K BRAW, uploaded to YouTube. Given the lighting conditions have changed from the clip in post 72 (above), which in your opinion has the better highlight handling, Ursa12K or Sony F55 ?
Can we see the uncorrected clip?
Problem was they want some of that 1% Hollywood market share but that will just never happen because ARRI is too powerful.
I doubt it. I think it's pretty clear GP wanted to appeal to the 1% but the adaptation is likely more difficult than envisioned.
BM has always been aggressive, but that price cut is too drastic to make any corporate sense.
I do suspect that the current price is where BMD wanted to land the camera from the outset, but I highly doubt that it was aiming for the Hollywood market due to its size.
The streamers however, the likes of Netflix, Amazon, etc don't care nearly as much about the brand of camera they use as long as it works and gives them the look that they want.
Not having ProRes support probably inhibited its uptake, and the fact that while the SDK is in beta it's available ONLY in Resolve, plus why would anyone WANT ProRes as 8 or 12K The data rates would be ridiculous. Even at 4K, I have yet to find any justification for using ProRes, because 8K Redcode (and I 6K Braw) have lower data rates than ProRes 422, but more malleability than even ProRes 444.
I suspect that the 12K sensor design will make its way into more cameras in BMD's lineup over time, since its so scalable. I don't know of any other cameras that can record raw at non-native resolution without windowing, which is a pretty nice benefit. That plus the frame rate options are pretty compelling, but maybe BMD is planning a Pocket model using the same sensor, but with the max resolution and frame rates reduced so that it doesn't need as much built-in processing power in order to target a lower price tier and lower power consumption.
