SOLD Blackmagic Ursa Mini 4.6k EF + V-Mount Plate + V-Mount Battery
Status
Not open for further replies.
neweditor
Hello, for sale is a Blackmagic Ursa Mini 4.6k EF + V-Mount Plate + V-Mount Battery
Asking $3500
I also have it on Ebay with the same listing title under the user-ID prodigal91 w/ 273 Positive Feedbacks (which I'd be glad to verify ownership of)
This remarkable camera was purchased only a few months ago and was used for our studio-only short film. A total of 20 hours of usage. With filming completed, we are selling to recoup production costs.
For its short usage, it was treated with the utmost care (straight from Pelican Case to Tripod) and so remains in LIKE-NEW/MINT, practically Brand-New Condition. It is essentially in the same condition as buying it off the shelf, as there is not even a blemish on it. Sensor is flawless. Even the box appears brand new.
The V-Mount Battery Plate on the back was installed professionally and is IDX i.e. "not the cheap stuff" and is solid as a rock.
The Dracast 90WH V-Mount included was recharged only a few times, and is also practically in brand-new condition.
DaVinci Resolve has never been registered and will provide you with the full license for the full version of the software.
INCLUDED:
- Blackmagic Design URSA Mini 4.6K Digital Cinema Camera (EF-Mount)
- IDX System Technology V-Mount Adapter Plate for Blackmagic URSA & URSA Mini
- Dracast 90Wh 14.8V Li-Ion V-Mount Battery
- EF-Mount Ursa-Mini Body Cap
- Side Grip
- LANC Cable
- Power Supply Combo
- Extra Connectors (not shown in pictures but in the box - hit the picture limit)
- DaVinci Resolve Full-Version License Dongle
- Software Manual for DaVinci Resolve
- Software Manual for URSA Mini 4.6k EF
- 1-Year Warranty
With this setup you have everything you need to begin shooting out of the box!
*I also have for sale a Dual Dracast V-Mount Charger and 2x Dracast V-Mounts identical to the one included. If interested, check out my other items for sale and I would be glad to provide a bundle discount! Thank you.
If you have any questions, please feel free to ask.
FREE Expedited Shipping to US.
PRODUCT INFORMATION
Now in a smaller, more handheld friendly form factor, the URSA Mini 4.6K Digital Cinema Camera from Blackmagic Design can record cinematic images with its Super-35mm 4.6K, sensor with 15 stops of dynamic range. The ergonomic body design is balanced and can be used for many different styles of filmmaking. The EF-mount is compatible with a plethora of popular lenses, opening up different aesthetic options. A rosette on the side of the camera accepts the included side handle which can control start/stop via a LANC connection.
To produce cinematic images, the URSA Mini can record raw sensor data in the CinemaDNG format onto CFast 2.0 memory cards at up to 60 fps. The raw files preserve the full dynamic range and color tonality output from the sensor so you can have greater control over the look in post-production. However, data-heavy uncompressed raw files aren't always easy to deal with on-set, so in addition to uncompressed raw recording, the 4.6K URSA Mini provides compressed raw recording at 3:1 and 4:1 compression ratios to save space while retaining post-production flexibility.
The URSA Mini also records UHD (3840 x 2160) and 1080p video using ready-to-edit ProRes files in many different flavors within the 444 and 422 chroma subsampling variations depending on your workflow. Starting at the high end, UHD footage can be recorded in ProRes 444 XQ at a rate of 312.5 MB/s all the way down to 1080p in a ProRes 422 Proxy file coming in at a relatively paltry 5.6 MB/s data rate. Since the camera accepts dual CFast cards, you can record for long periods of time by having the camera switch cards when one is full.
Power for the URSA Mini can be supplied via a 4-pin XLR jack at the rear of the camera. With an optional plate, the URSA will accept professional V-Mount or Gold-Mount batteries on the back. Once connected to power, the URSA can even distribute power through a second 4-pin XLR jack.
Camera Features
Compact Handheld Design
Sizing down the familiar URSA shape enables the URSA Mini to fit into feature film, indie film, TV, commercial, documentary, and music video workflows with crews of any size. Using the optional shoulder mount with a built-in quick-release plate, the URSA Mini can go from handheld to shoulder to tripod in a matter of seconds. Despite its size, the URSA Mini still fits essential I/O for professional workflows.
The body is made from Magnesium alloys in order to keep the URSA Mini lightweight at 5 pounds. To make the camera more acceptable for handheld usage, a side handle is included. With the optional shoulder mount, the handle can be extended off the side of the camera to be used in a doc-style configuration.
4.6K Super-35mm Sensor
With an effective resolution of 4608 x 2592, the sensor housed inside the URSA Mini can capture motion pictures that have greater-than 4k resolution with a film-like 15 stops of dynamic range. A wide exposure latitude allows for greater control in post, enabling highlight recovery while keeping the shadows clean from artifacting.
The URSA Mini can record the entire sensor at up to 60 fps to fit television or other workflows which require higher frame rates. Using a smaller portion of the sensor, the URSA Mini can also record slow-motion footage at up to 120 fps in 1080p resolution. When recording high frame rates, the URSA Mini will conform captured footage to the set standard frame rate resulting in smooth footage that doesn't require post processing before editing.
Touchscreen Control
In addition to more traditional button-driven menus, the URSA Mini features a fold-out 5 inch 1920 x 1080 resolution capacitive touchscreen LCD monitor. Using the easily navigable touchscreen menu you can see and change all camera settings, view timecode, histograms, audio levels, and focus peaking, as well as add shot metadata with an onscreen keyboard.
Professional Connections
The URSA Mini features multiple connections such as 12G-SDI out, HD-SDI monitoring out, 2 LANC inputs, balanced XLR audio with phantom power, timecode-in, and reference input. On the front right side of the camera the 4 pin XLR DC and HD-SDI monitoring output are located in the perfect position for connecting to an optional viewfinder or on set monitor. The 12G-SDI output handles up to 2160p60 using a single BNC cable and also switches to 6G-SDI or HD-SDI depending on the shooting format.
Quality Sound Recording
With high quality built in microphones and professional audio recording features you don't have to carry around extra sound equipment. You can use the built in stereo microphone to record natural location sound or connect professional microphones using the two XLR mic inputs. The XLR connections have 48V of switchable phantom power so you can plug shotgun mics or wireless lavalier mics for capturing more detail. You can quickly adjust levels using the physical knobs while monitoring the audio using the onscreen audio meters and headphones.
Multiple Power Options
On it's own, the URSA Mini includes a 4-pin XLR industry standard power connector that works with 12V to 30V external power supplies. That means it's easy to use the camera with existing professional power supplies and batteries. The camera uses the same battery power connector and mounting points on the rear of the camera as used on the original URSA so you can use the same range of battery plates from a wide range of manufacturers such as IDX, Frezzi, Anton Bauer, and more. You can also add the optional Blackmagic URSA V-Lock Battery Plate for using popular V-Mount batteries.
DaVinci Resolve Software Included
Included with the camera is a DaVinci Resolve USB dongle, which contains a license to unlock the full feature-set within the software. The full version of DaVinci Resolve is compatible with Mac and Windows, and can be used for editing, color grading, media management, mastering, and delivery. DaVinci Resolve can easily handle the 12-bit log RAW images from URSA Mini so you can take advantage of URSA Mini's amazing image quality and wide dynamic range. DaVinci Resolve features advanced, multi layer timeline editing with powerful trimming tools, along with the industry's leading suite of creative grading tools
Sensor
Size 25.34 x 14.25 mm (Super-35)
Lens Mount Active Canon EF
Effective Resolution 4608 x 2592
Dynamic Range 15 stops
Shooting Resolutions 4608 x 2592
4096 x 2304 (4K 16:9)
4608 x 1920 (4K 2.4:1)
3840 x 2160 (Ultra HD)
3072 x 2560 (3K Anamorphic)
2048 x 1152 (2K 16:9)
1920 x 1080
Frame Rates 23.98, 24, 25, 29.97, 30, 50, 59.94, 60 fps
Display
Dimensions 5" diagonal
Screen Type LCD capacitive touchscreen
Resolution 1920 x 1080
Recording
Media Card Slots 2 x CFast 2.0
Recording Formats CinemaDNG Raw (Uncompressed or Lossless 3:1/4:1 Compressed) @ 4608 x 2592, 4096 x 2304, 4608 x 1920, 3072 x 2560, and 2048 x 1152 (film dynamic range)
Apple ProRes @ 3840 x 2160, 1920 x 1080 (film or video dynamic range)
Data Rates 4608 x 2592:
Uncompressed CinemaDNG Raw - 513MB/s
CinemaDNG Raw 3:1 - 180 MB/s
CinemaDNG Raw 4:1 - 135 MB/s
3840 x 2160:
Apple ProRes 444 XQ - 312.5 MB/s
Apple ProRes 444 - 165 MB/s
Apple ProRes 422 HQ - 110 MB/s
Apple ProRes 422 - 73.6 MB/s
Apple ProRes 422 LT - 51 MB/s
Apple ProRes Proxy - 22.4 MB/s
1920 x 1080:
Apple ProRes 444 XQ - 62.5 MB/s
Apple ProRes 444 - 41.25 MB/s
Apple ProRes 422 HQ - 27.5 MB/s
Apple ProRes 422 - 18.4 MB/s
Apple ProRes 422 LT - 12.75 MB/s
Apple ProRes Proxy - 5.6 MB/s
Rates based on 30 frames per second.
Metadata Support Automatic camera data and user entered data such as shot number, filenames, and keywords
Connections
Output 1 x 12G-SDI -- 10-bit 4:2:2
Reference 1 x Reference input
Timecode 1 x Timecode input
Analog Audio Inputs 2 x XLR -- selected mic/line level and +48 V phantom power
SDI Audio Output 2-channel
Remote Control 2 x LANC on 2.5 mm sub-mini -- controls record START/STOP, iris, and focus
USB 1 x USB 2.0 mini type B for software updates
Supported Standards SDI Compliance: SMPTE 292M, SMPTE 424 Level B, Draft SMPTE 2081-1, Draft SMPTE 2082-1
SDI Audio Sampling: 48 kHz and 24-bit
General
Microphone 2 x Built-in cardioid microphones for stereo recording with -10dB pad and low-cut filter
Speaker Integrated mono (enabled in playback when headphones are not used)
Controls Touch screen menus on 5" screen, push button controls for navigating menus
Mounting Options Integrated rod mounts compatible with 15mm Light Weight Support (LWS) standard
System Requirements Mac OS X 10.9 or newer, Windows 7 (64-bit) or 8 (64-bit)
Note: See Blackmagic website for detailed system requirements and configuration guides.
Power Connectors Inputs:
1 x 4-pin XLR input for external power supply or battery
1 x 12-pin molex connector on rear battery plate
Outputs:
1 x 12V output using 4-pin XLR for powering external accessories such as EVF
1 x 12V regulated output from rear molex 12-way connector
Battery Plate Support Mounting holes for V-mount and Gold Mount battery plates
Operating Temperature 32 to 104°F / 0 to 40°C
Storage Temperature -4 to 113°F / -20 to 45°C
Humidity 0 to 90% RH, non-condensing
Dimensions 8.2 x 7.6 x 5.8" / 21 x 19.3 x 14.7 cm
Weight 5 lb / 2.3 kg
Status
