djmfoxtrot
[FONT="]Blackmagic Intensity Shuttle video capture card[/FONT]
[FONT="]The Blackmagic Design Intensity Shuttle is a 10-bit HD/SD video capture/playback device that supports USB 3.0, and allows you to capture 10-bit HDMI or analog video directly from a camera onto your computer for professional editing or mere playback. With a neat, compact design, the Intensity Shuttle is very portable and easy to set up. As the input and output connections are on different sides, you can simply plug the unit in line with your existing cable setup.
[/FONT]
[FONT="]Supporting HDTV 1080i/59.94, 1080i/50, 720p/59.94, 720p/50, the Intensity Shuttle allows easy and instant switching between HD and SD video standards. Additionally, using the USB 3.0 interface eliminates the need to compress visual data and thus saves on CPU processing power; this allows your CPU to solely focus on HD real-time effects. The video capture/playback device draws power from the USB 3.0 connector itself, and eliminates the need for a dedicated power source.
[/FONT]
[FONT="]Fully compatible with multiple software image-editing solutions such as Premiere Pro, Photoshop, After Effects, Fusion, and Nuke, the Intensity Shuttle also supports all Windows USB 3.0 computers.
[/FONT]
[FONT="]Retails for $189 at B&H: [/FONT][FONT="]http://www.bhphotovideo.com/c/product/686585-REG/Blackmagic_Design_BINTSSHU_Intensity_Shuttle.html[/FONT][FONT="][/FONT]
[FONT="]Used only once for a television broadcast commercial. In box with all accessories for only $110[/FONT]
For sale only within the Continental U.S.
Item may be picked up in West Palm Beach, FL.
[/FONT]
[/FONT]
[/FONT]
