pawitter parmar
Hello Every One,
i'm going out of business i know it's SAD but that life. Show must go on.
Selling each and every thing i have or listed in this form if this is more confusing for all of you guys you can contact me on my cell +91-987-861-7299 or my son TJ 647-823-6964 WhatsApp me or TJ same number or email me at : pawitterparmar@gmail.com these are the fastest way contact me sorry i don't go on Reduser more often to check my PM etc..
Prices in Canadian dollars.
payments can wire transfer canaidan accounts etc. i am Canadian my self & I'm 200% Genuine buyer & seller many years on Reduser buy with confidence guys . All of my gear setting in toronto, Canada residence can ship world wind . Thanks
The Blackmagic Design HyperDeck Studio 2 is a file-based deck that features the same functionality and control of professional tape decks. It records uncompressed video with 4:2:2 color sampling at 10-bit in Quicktime format, and also records video using either ProRes or DNxHD codecs. With two SSD slots, you can record almost endlessly as one SSD becomes full, recording automatically continues on to the other. The HyperDeck Studio features one 3G-SDI input and three SD/HD/3G-SDI outputs plus a loop through output, and one HDMI input and one HDMI output. All outputs, except the loop through SDI, are always active, so playback is available on both the SDI and HDMI outputs no matter what input it was recorded from.
The Studio 2 is a 1RU rack mountable unit, with built-in rack mount ears. It features illuminated front panel button control and a jog/shuttle wheel for analog scrubbing. RS-422 control is supported for external control. You can also control the unit using either the USB port or over Ethernet via the RJ45 connector. An integrated LCD on the front panel allows you to monitor the video, and display timecode and transport information.
PRODUCT HIGHLIGHTS
1RU File-Based Video Recorder
Records Uncompressed 10-bit 4:2:2
Records Compressed in ProRes / DNxHD
Records on Two 2.5" SSDs
1 x 3G-SDI Input, 3 x Outputs
1 x HDMI Input, 1 HDMI Output
Outputs are Always Active
Front Panel Button, Jog Wheel & RS-422
Multi-Display Integrated LCD
https://www.bhphotovideo.com/c/produ..._2.html?sts=pi
PRODUCT HIGHLIGHTS
