Moz
http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=191001097526
Found this while cleaning out some gear. it was used for a DIT station back in 2011 for a project but during prep they went with a different system. Been in storage ever since.
Open to offers, maybe trades.
The Blackmagic Design DeckLink HD Extreme 3D is a capture card that allows you to connect, capture, and playback SDI, HDMI, analog component, S-Video and composite media on Mac, Windows, and Linux computers. You can use the HD Extreme 3D card with software such as Final Cut Pro, Premiere Pro, After Effects, Photoshop, Fusion, and ProTools.
With regular 2D and 3D stereoscopic workflow support, you can use the Decklink HD Extreme 3D card for single and dual channel SDI capture and playback. Integrated into the HD Extreme 3D card are dual link 3 GB/s, SD, HDMI 1.4, and analog/composite/S-Video connections. Also integrated is support for SD, HD, 3GB/s, HD-SDI, and 2K in 4:2:2 and 4:4:4.
You are provided with a host of control options in the form of AES / analog balanced audio, 16-channel SDI audio, Genlock, and deck control. The HD Extreme 3D card supports video formats up to 1080p60. Integrated into the DeckLink HD Extreme 3D is the up, down, and cross conversion features. Also included is a built-in SD/HD internal keyer. In addition, you can use the HD Extreme 3D card with a wide array of video and audio equipment such as HDCAM, HD-D5, HDCAM SR, Betacam SP, and the Digital Betacam.
- Capture card - allows you to connect, capture, and playback SDI, HDMI, analog component, S-Video and composite media on Mac, Windows, and Linux computers
- Supports software such as Final Cut Pro, Premiere Pro, After Effects, Photoshop, Fusion, and ProTools
- Supports regular 2D and 3D stereoscopic workflows
- For single and dual channel SDI capture and playback
- Integrates dual link 3 GB/s, SD, HDMI 1.4, and analog/composite/S-Video connections
- Offers support for SD, HD, 3GB/s, HD-SDI, and 2K in 4:2:2 and 4:4:4
- Includes a host of control options in the form of AES / analog balanced audio, 16-channel SDI audio, Genlock, and deck control
- Supports video formats up to 1080p60
- Offers the up, down, and cross conversion features
- Includes a built-in SD/HD internal keyer
- Supports a wide array of video and audio equipment such as HDCAM, HD-D5, HDCAM SR, Betacam SP, and the Digital BetacamCompatible with Mac, Linux, and Windows
