Erik Naso
Pulled from Mac Pro system. Works great in Mac or PC. Comes with all the goodies in the pictures.
$275 with FREE shipping CONUS with Paypal friends and family payment.
The Blackmagic Design DeckLink HD Extreme 3D is a video-editing hardware, which features single and dual-channel SDI capture and playback for both regular 2D as well as new 3D stereoscopic workflows. It includes dual link 3 Gb/s SDI, HDMI, analog component/composite/S-video connections and 2 channels of AES/EBU audio in and out with a sample rate converter on the AES/EBU input as well as 2 channels of XLR professional analog audio in and out. It is the first capture card to include high speed 3 Gb/s SDI connections for 4:4:4 RGB, 2K film, and 3D; the 10 Gb/s super fast connectivity makes for superior real-time effects. The video formats can be instantly switched between SD, HD, and 2K up to 1080p60. This unit is compatible with NTSC and PAL formats.
The Extreme 3D includes 16 channels of SDI embedded audio support for HD and 8 channels of SDI embedded audio for SD capture and playback with added genlock and deck control features. It is equipped with a fast video processor for 10-bit quality hardware up, down, and cross conversion. The built-in SD/HD internal keyer combines visual elements from separate sources into single images.
The hardware is geared up for 3D workflow using both interleaved and dual stream capture and playback. It works with a wide range of video software such as Apple Final Cut Pro, Adobe Premiere Pro, Adobe After Effects, Adobe Photoshop, and Eyeon Fusion. It also supports the widest range of equipment, such as HDCAM, HD-D5, HDCAM SR, Betacam SP, Digital Betacam, HD receivers, HDV cameras, televisions, mixers, and more.
Single and dual-channel SDI capture and playback for both 2D as well as 3D3G SDI (3 Gb/s SDI) I/O, HDMI 1.3 I/O, analog component/composite/s-video I/OFull resolution HDMI I/O for connecting to any 2D or 3D HDMI TV or video projector for full HD resolution monitoring2 channel AES/EBU unbalanced audio I/O, 2 channel balanced analog audio I/O3 Gb/s SDI allows 4:4:4 RGB, 2K film, and even 3D with a single BNC type connectionCapture and playback 4:4:4 video when used with decks such as Sony HDCAM SR, or view real-time playback of 2K film resolution at 24 fpsSuper fast 10 Gb/s connection provides unmatched real-time effectsSwitch between SD, HD, and 2K video formats up to 1080p60Compatible with NTSC and PAL16 channels of SDI embedded audio support for HD as well as 8 channels of SDI embedded audio for SD capture and playbackGenlock for video output synchronizationControl a deck remotely via RS-422 for capture and playback of clips with timecode accuracyIncludes a powerful video processor for incredible 10 bit quality hardware up, down and cross conversionBuilt-in SD/HD internal keyer for compositing of imagesUses both interleaved/side by side and dual stream capture and playback for advanced 3D workflowCompatible with a wide range of equipment as well as software for optimum system integration
