[FS: General] Blackmagic ATEM 1 M/E Production Studio 4K Switcher $ 2500 CAD
Hello Every One,
i'm going out of business i know it's SAD but that life. Show must go on.
Selling each and every thing i have or listed in this form if this is more confusing for all of you guys you can contact me on my cell +91-987-861-7299 or my son TJ 647-823-6964 WhatsApp me or TJ same number or email me at : pawitterparmar@gmail.com these are the fastest way contact me sorry i don't go on Reduser more often to check my PM etc..
Prices in Canadian dollars.
payments can wire transfer canaidan accounts etc. i am Canadian my self & I'm 200% Genuine buyer & seller many years on Reduser buy with confidence guys . All of my gear setting in toronto, Canada residence can ship world wind . Thanks
The Blackmagic ATEM 1 M/E Production Studio 4K is a live event multi camera production switcher with 10 individual Ultra HD inputs built into a 1RU chassis. Supporting NTSC/PAL/HD and Ultra HD video formats, the switcher connects to a wide range of cameras and sources, delivering a single program stream in SD, HD, or Ultra HD video. All this is done live and in real time with no rendering required. The switcher features a reference video input for synchronizing the switcher to other equipment using tri-level or blackburst sync. Each input also features its own frame synchronizer, which allows you to use cameras that do not feature Genlock as well as input video from computer sources.
The switcher provides 8 video outputs that are always active. It features two SDI and one HDMI Program output, both of which deliver SD/HD/Ultra HD, with one aux SD/HD/Ultra HD output that can deliver a clean program feed without any downstream effects. The switcher also features a down-converted HD output for monitoring on an SDI-equipped HD monitor. Multi view monitoring is 1080i only, over dedicated SDI or HDMI output, and multi view allows you to view the program, preview, and eight live sources at the same time. The switcher features built-in luma and chroma keyers for real time effects and composites in Ultra HD, with 10-bit processing. Two downstream keyers allow you to use two graphics/logos/titles/lower thirds from up to twenty stored graphics in a wide variety of formats.
A built-in twelve-channel audio mixer handles the embedded HDMI and SDI audio from the 10 active video inputs as well as audio from the balanced or unbalanced analog audio inputs to provide you flexibility and creative audio options. Audio output is embedded in the SDI and HDMI stream, as well as available via balanced audio outputs. Either a Mac or PC running the included ATEM Software controls the switcher's operation and settings. For those who like the feel of a physical control panel, available ATEM ME 1 and ME 2 Broadcast Panels, connected via the Ethernet port, also control all the features of the switcher. Illuminated front panel buttons allow you to locally select the aux output, while a 2-inch LCD screen built into the front of the unit allows you to see the aux output for instant confirmation of the correct output.
https://www.bhphotovideo.com/c/produ...roduction.html
PRODUCT HIGHLIGHTS
Supports NTSC/PAL/HD/UltraHD 4K @ 10-bit
Supports 4K Resolution Over SDI or HDMI
10 x 6G-SDI & 1 x HDMI Inputs (SD/HD/4K)
Tri-Sync/Blackburst Ref. Sync Input
10 x Built-In Frame Synchronizers
Multiview Monitoring in HD
Program Outputs in SD/HD/4K HD
4 x Keyers Total: 3 x Luma, 1 x Chroma
12 x Channel Audio Mixer
Hardware or Software Mac/PC Control
