Hi,
I am not a pro so I'm just reporting something that came to my attention. After using cgipro's script to fix the stair-stepping on a file, I used InstantHD to convert it to 1080p and that's when I saw a grayed line across the bottom:
After further investigation, I realized that it happened because of a row of black pixels at the bottom which is also found in the original footage. InstantHD must be trying to blend the doubled black row into the expanded image, creating the grayed row. If I crop this last row out, it gives me a clean image at 1080.
So, my D90 seems to produce a 1280x719 image plus a row of black pixels at the bottom. Here is a frame over a blue background:
I was thinking that cgipro's script (and other Stair-Stepping removal scripts) could be modified to include a crop of this last row in order to have a clean footage. I'm not sure how much the ratio becomes an issue but I could not see a real difference when going from 1280x800 to 1920x1080 compared to 1280x801. However, if there is a way to keep the ratio intact, I would prefer it.
If I knew a bit about AviSynth script syntax, I'm sure it would be as simple as adding one line of code.
I hope I'm not seen as "anal" after this
