black balance?
Tony_Reyes
I have a decent understanding of white balance but what is black balance?
Can anyone help me out here with a reasonably detailed description?
Thanks in advance.
Just as the relative levels of the 3 colors from the sensor need to be "balanced" (calibrated to each other) at their brightest values for and accurate white point; they also need to be balanced relative to each other at minimum light values, their black point.
Basically white-balancing moves the dot respective to white to the center of a vectorscope, and black balancing moves that black dot to the center too.
- Mikko
The camera shuts the iris and looks at the chipset. With no light coming in you'd expect that the chips would be delivering a completely black image. If it isn't, the camera figures out what portions aren't perfectly black and adjusts them so that they will be black.
i haven't been asked to do a black balance yet. so if the iris closes, i don't need to be pointing the lens and anything black? like what you're doing when you white balance?
Correct -- the iris closes completely, so it doesn't matter what you point it at. And you should do a black balance every once in a while anyway.
