Chamber005
Carbonite Member
So, I can't be the first person to ever try this, but I can't seem to locate the answer I'm looking for.
I have an older professional camera (DSR200) that's no longer able to be used as a viable camera for several different reasons. It still records just fine and has an XLR 3-pin interface, etc.
What I'm wanting to do is to use something like an HV30 or HF200 for visual and use the busted camera for audio and then synch them in post.
So I was wondering, if, for instance, I used the HV30 at 24p, and the DSR records at 30p, how exactly could I go about synching it? Or, more to the point, would I need to worry about synching it if there are going to be multiple cuts? Like, from my understanding when you record 30p audio and place it against 24p video, you eventually have something that goes out of synch -- eventually.
Is that true? Would the average person not be able to notice the synching issue if the frames/recording were essentially restarted every 20-30 seconds?
Hopefully this question isn't too bizarre or ill-informed.
Thanks so much for your help!!!
