I have a question about bitrate.
I installed the hack using Andrew Reid's guide from EOSHD . com
So my settings are the "c" settings.
When i use log and transfer in FCP and then check the item properties of the clips i've imported, it says that the data rate is between 12-14 MB/sec (which seems quite low)
When i export these clips as a .MOV and open them in Quicktime and press cmd + i for info, it says that the data rate is 115+ MB/sec.
This doesn't really make sense to me, so i was hoping that someone could tell me how to check the bitrate properly.
