I am confused and would appreciate a little light being shed one my limited understanding of NLE's color bit-rates.
First of all... up to Vegas 7 Sony was in the 10-bit world right? I forget... for a second I was thinking it was 8-bit.
Secondly, does the HVX record in 8-bit?
If so... 8-bit is 256 possible values for each of R G B right? Is that only the Chroma value and then there is an added Luma value per pixel in the footage? Wouldn't 0 0 0 be black and 256 256 256 be white? And wouldn't grays be also possible with equal values of RGB such as 100 100 100 and such...?
I understand that the added bit-rate during CC can help if you are applying multiple color corrections so that there is less degradation from the "imperfections" of of these processes. So is it that during the rendering process the higher bit-rate is used, however when rendering for say DVDs the file being rendered ends up again being three 256 values? Right?
What's the bit-rate for DVDs? Is it the same for Blue Ray? What about the HVX?
I am sorry about my lack of knowledge if there is some horrible aberrations above this disclaimer guys
I am still trying to pick up these things that most of you have known and worked with for a long time.
