Lyndrick Collins
Wanting to mix GH2 24p footage with Sony Action camera Footage.
Let's say you have an Action camera with the following specs:
1080p at 50fps Bit Rate = 28mbps
1080p at 25fps Bit Rate = 16mbps
You intercut the 50p (25p) (Close range and POV) with Multicam DSLR footage of 24p (Medium and Wide).
You Drop the Footage into a 24p timeline with a 24mbps Bit Rate and have the option of either dropping frames or bending frames.
1- How much information is lost conforming 50p to 24p?
2- Will the amount of information lost from the 50p footage lead to the 25p (16mbps) footage maintaining a higher Bit Rate in the 24p timeline?
3- Is it better to drop the 50p into a 25p time line, render at 25p, and then drop the new file into the 24p timeline?
4- Is it better to just forgo the 50p and use the 25p (16 Mbps)?
