Better P2 card to take out the camera ?
cane
When not record or something or put the camera off
Is it then better for the camera or the P2 card to take out the card and save carefull somewhere ?
Or is this not neccesary and when the card is in the camera you always reeady to shoot.
Hello Cane,
I'm having a tough time with your question but I think that you are asking if it's better to store the P2 card in the camera or outside of the camera in some sort of protective case.
If that is the question, then here is the answer. The HVX200 slots are made very well. There isn't any movement possible when the cards are inserted. Also the pins on the card and the camera are both gold plated so you don't really have to worry about corrosion.
In any case that you NEED to have your card outside the camera, please put it in it's protective case (unless you're using it in a laptop, P2 store etc.)
Has someone had an experience that says otherwise?
I hope that I answered your question.
Best regards,
Andrew Hoffman
Senior Operations Manager
Specialized Communications Corp.
20940 Twin Springs Dr.
Smithsburg, MD 21783-1510 USA
800-359-1858
301-790-0103
Fax: 301-790-0173
andrewh@spec-comm.com
www.spec-comm.com
Please visit our new online store at ( http://www.spec-comm.com/store ). New products being added daily!
Thanks for reply Andrew
And sorry if this question take your time because I'm not using the right words .
But your answer was exact the right one what I was looking for.
P2 card it is not a cheap medium so that's why I whant to know can the P2 card system damage when it will store in the camera.
Best regards
Cane
