betrayalFEST - VIEWING NOW OPEN
thanks for the heads up. there was one film missing from the last zip as well, but that was just updated, so if you've downloaded the last zip prior to this message you are missing _Luis' film "The Rule of Thirds"
Was just testing the download of "myPhone" and it stopped at 10.4 MB. Might one of the mirrors not have the entire file?
EDIT: A 2nd attempt got the whole thing. Could have just hiccuped, but I was downloading a zip at the same time and it's still going.
EDIT 2: I noticed that the first time during the download it said the file size was 56.6MB, when it's actually 59.4MB, and then it stopped downloading at 10.4MB.
EDIT 3: Also, when I start to download a zip I get this at the top of the page: "Warning: filesize() [function.filesize]: stat failed for /home/fest_admin/dvxfest.com/mirror/betrayal2010/entries/betrayal0006.zip in /home/fest_admin/dvxfest.com/betrayalfest/index.php on line 45" Stil downloads though.
Just tried this, still can't get zip 8. Will re download zip 10 though for the missing film from it.
just try it again until you get a different server...
otherwise, take the link I posted above and change 01.zip to 08.zip and you should be able to grab it that way.
One of the servers didn't get the zips right. Larry is taking care of it. In the meantime, download again until you get a working server, or use the link I posted above.
If you happen to see the name of the server on any film or zip that is not owrking, please also post it here.
Later,
Jason
Just tried zip 8 and got it on the first try.
Try this link:
http://dvxfest.ramjetfilms.com/betrayal2010/
scroll down and direct download the zip you need. I'd prefer that folks go through the system if at all possible though and not circumnavigate it as it helps us with stats tracking, and of course to find errors so that we can fix them.
Later,
jason
For whatever reason, the first few after CHARL(Y)IE FACTOR download to 8-10mb, and when I try to watch, I get a green screen about a minute in.
Same issue with 8 here, but I just tried the link again and got it. You just have to hit right in the cycle through the mirrors.
please list any films that you have trouble with. If possible, also list the server you pulled it from.
Thanks.
Later,
Jason
Same here. I've spot checked some, including both of mine, and occasionally only download around 10MB. I notice that the progress shows a lower finishing file size than when they download properly. Example, both of mine show 56.6MB when the download will stop at 10MB, but shows 59.4MB when the download will fully complete.
Zip 6 and 7 are the same. "myPhone" is not in any Zips, except I'm still downloading 9. Hopefully it's in there, but these seem to be in alphabetical order.
Edit: I got 9. "myPhone" is not in it or in any others.
I count 4 missing films. There's supposed to be 48 films right? I downloaded all zips and have 44 films. Is that because Zip 6 has the wrong films?
I think there is 49 entries in total...
if you can let me know which films are missing from the zips in contrast to the list on the viewing page, I can pass that along to larry to get those included in a new zip file
